Hi
Has anyone else had issues with faulty MK2 550s? One on the bench this week, failed big end bearing, which killed the cylinder. 269 hours run time on coppicing, so not thrashed. E5/XP oil. 21/2 years old, Husqvarna didn't want to know. I'm getting a little fed up of rebuilding early failed Huskys!!
Any thoughts?
Graeme
Coppicing often means revving flat out near max revs rather than at around 9,000 as normal. What sort of oil was it running and was it fresh mix.
Edited by spudulike
Spelling
I must confess I have not seen many big end bearings, plenty of main bearings though, these saws really suffer with the flywheel side seal leaking like a hole in a bucket, could this have been a factor in this failure?
