Getting fed up with the quality of husky kit, new combi 525 has stripped 2 drive shafts in 18 months, poor starting when hot ( i have checked coil gap and reset ) stripped the bolt where you tighten the attachment twice, is the Stihl combi  any better ? dont want to switch brands as i have pole saw,hedge cutter etc for the husky, thinking i might try the cheaper 129 and treat it as  a " throw away " tool after a year or so ??
Any thoughts
Cheers
I think the Stihl engine is good, they changed the design of hedge cutter gearbox a few years ago and it's now lighter (which is good) but less durable. I've got the 4 stroke engine which is fine, it has a maintenance on valve clearances that people forget, now the newer KM94 is 2 stroke so taken away that problem.
Don't think you'd suffer the same as it seems you have with that one.
This is why I don't like combi systems . They are a compromise ( as is life ) . I have a dedicated machine for each job . Single sided hedge cutter , double sided long reach hedge cutter long reach pole saw and 2 strimmers ( 45cc and 55cc )  I know its more kit to carry but the job gets done with less hiccups .
I'm surprised to hear about the drive shafts stripping probably because I have a few walk in customers that have the 525 and they haven't had any issues with drive shaft failures but the hot start may just be down to the carb needing a bit of a tune. Ive had to tune a few but its mainly been down to poor running. Its always worth giving the primer bulbs a few pumps as that can help with a hot start.
Its probably the best part of a £1000 to swap over to Stihl with the accessories so it might be worth investigating the issues on the 525. The Stihl kombis are fairly reliable though and I dont recall replacing any drive shafts. Its mainly drive shafts on the bent shaft strimmers that fail, usually down to old age or using the strimmer without a guard.
