I have the same rule around the farm, including myself regarding PPE, it might be hot but I'd rather be safer.
It'll all be digitally monitored via hall effect sensors, so would also assume a cut into kevlar is a rapid change Vs say a cut bogging it down slowly curve.
But these controllers are insanely accurate, we modified a motor in industry and even without the sensors we soft started and had it running at around 20rpm variance at full chat almost regardless of what load. Granted it's a thirsty beasty amps wise, but it also safety stopped in milliseconds if for example a t-shirt got wrapped around the mechanism it was that sensitive.
Think it depends on how cheap you go, even the Screwfix electric stopped almost on the button. It was like a wet lettuce but think it was like 1500w Vs my daily ms261.
On 05/01/2025 at 09:24, CCTree said:
I’ve booked for cs30/31 in Feb and need a new saw - the basic Husky we use for logs will not cut it, so to speak. I also have a GTA26 and a reasonable collection of Silkys.
I’ll be using it for Hazel coppicing, Laurel and Rhody removal, the occasional small tree - I’m a gardener in Cumbria, but we have some small wooded areas and plenty of ponticum. Big stuff is dealt with by other staff members/arb crew, I’m not looking to move onto bigger stuff.
I’m looking at MS251 C-BE
Any recommendations?
The problem with cutting ponticum with a petrol saw is you are permanently putting the saw down to untangle and move things.  Id go with an electric saw for this. Even one of the smaller one handed ones in whatever cordless system you already have.  I have a makita one like this for bonfiring
Makita DUC101Z Solo
Beyond that, everyone should have a 50cc petrol chainsaw.
So, I have the GTA 26 and an MSA 60 (first gen, not CBE) with a 12" bar for smaller clearance work. These are great for a bulk of the ponty clearing - as you say, you can stick it down and pick it up as needed. I'm keen to get a petrol chainsaw too though - on a 10+ acre site in Cumbria (everything is uphill), it's a pain in the ass to charge batteries or drag half a dozen of them into the woods for a big day out.
I'm accidentally (battery) Stihl loyal - I run an RMA 448 battery mower, FSA 135 brushcutter, FSA 60R strimmer, HSA 60, 100 and HLA 86 hedgecutters.
I was tempted by CBE, but definitely do not want to be adjusting every 10 seconds - the GTA needs forever micro-adjusting now it's 2 years old.
I like the look of the Husqvarna 560xp - and that seems to avoid the single nut issue that has been mentioned with the Stihl. Any draw backs with it?
I don't have any husquarnas but
It seems 560xp - auto tune
I.e. 460  tune it yourself,  if need be
Some more experienced members may comment on reliability of either, and dependence on dealer with software if need be
Edited by Dave1976
Auto-tune is fine, works great, don’t worry.
560 is a biggish saw, unless you need real felling power, go smaller.
Edited by Mick Dempsey
Auto tune is fine, IMO most saw problems are generally down to use error.
Unless it is very large ponticum a 560xp is overkill.
For petrol, any smaller Husqy would do, an Echo CS4310 is a great little durable coppicing saw, or the Stihl MS212 which has become a favourite in the training world.
I am looking to buy ms212. Coming from ms170, would i see enough power increase ?
Its all relative together with what your expectations are .
Thanks for the comments here especially on lecky saws, I have one, an Einhelle and those comments have been very helpful to me, thanks again.
I only use it for fallen trees and limbs that no-one seems to care for to feed my log burner 😁
