@GarethMlooked all over, nothing touching blades
@Jase hutchonly when revs are slowing
Anyway tl bush is out, I cut a slot for pulling it out easier next time.
Now the 4 screws that house the bearing, very crap design, they are gonna be soldered to the wall.
Now I can't rotate the 2nd bearing from shaft, locking screws are out, hammer doesn't solve or fire or wd40.
Help again please.
Bearings within a housing like that need the whole assembly taking out as it's designed to leave very little space for things to wobble when running.
Usually easier to put them in a hydraulic press supported from behind and use the hydraulic ram to push the shaft out like a hub puller.
But to be honest, take it somewhere.
Plus that spacer is now fit for the bin, if as I suspect it's a locking bushing, it's now junk and needs replacing as it's integral to how it keeps things tight.
Edited by GarethM
