This is a typical cutting mechanism.  As I’m sure you know, it doesn’t have blades mounted on the face of a ‘flywheel’  like a conventional chipper.
The flywheel ( or in some cases, really heavy pulley wheel) is mounted on one of the shafts in the style of a vintage stationary engine flywheel.
Badged in Poland, just a reduction gearbox with blades.
I have memories of a version that used a gearbox and a woodchipper style flywheel that turns slowly to shears and roll the branch as it cut. Think it was posch or remet, typically over engineered and expensive
So the cutting mechanism is made in PRC or somewhere? Still a pretty simple piece and the steel is really thick - glad I had a tractor to lift it with
Wherever it's made, it seems pretty well made. Mine does have a large pulley as a flywheel. Not sure I'm actually running it fast enough - but 1900rpm on my tractor (for a 540rpm PTO) makes it sound like it's screaming
The smaller bits would probably be best burnt in a boiler at high temperatures - might experiment with burning them in a cage in the wood stove. Otherwise, they can just rot down and nourish the soil and I'll salvage the bigger chunks
Was it the Bilke?
Just now, scbk said:
Was it the Bilke?
That's the beasty I was thinking of, always thought the firewood it produced was garbage in the videos.
If I wasn't in a smoke control zone, I'd be buying a cheap polish woodchip boiler and cutting out all the hassle 🙂
