Petrol is not a clear colour, but most also likely absorbed oil from the last mix you had in the can once it got warm and the oils become more fluid.
Plus all plastics do age with both UV and petrol as it's a solvent, more noticeable with diesel and even kerosene as that's even more aggressive.
I've got yellow drums that are almost brown lugging diesel to small equipment.
The inherent colour of fuel is dependent upon the refining processes used to produce the blendstocks that
go into making a petrol grade. The colour of the blendstocks can vary from Colourless to Yellow depending
upon the refinery, the crude and the processes used to create each petrol blendstock.
Same pump, same fill, same cans, same historic contents, same everything. Left stored inside, right stored in sunlight.
Or the butler but I suspect that he is, in this instance, not guilty.
Edited by AHPP
So you've answered your own question then, it must be the sunlight. Either directly or indirectly. Maybe the UV, or increased temperature, or both, cause a reaction between the petrol and plastic to happen at a faster rate than normal. Or something. Too many years since I though about any chemistry.
