Prune beech tree now or in the autumn/winter?
difflock
How big is the left hand branch? Rather than remove it completely, may be appropriate to subordinate it, so maybe reduce it by half so that it grows much slower than the main stem. That way your funny split union gets swallowed up rather than turned into a huge rot pocket.
Based in these few pictures, I'd say it's do-able and if you don't it will be an isse for the tree for all its life. So on balance, I'd remove it while the tree is still young and vigorous. But' you'd need to leave zero stub and the only way to do that is a small gob immediately below the bottom of the inculsion and then effectively tear off the part to be removed. You've probably seen natureal tear-outs in beech loads of times. The key is not to touch the bark of the arch of the tear-out AT ALL with any saw, and at the same time prevent the bark below being torn too far down the stem.
Personally I have long thought that the best success with pruning comes with mimicking nature, because trees have evolved to cope with branch losses for 100s of millions of years. So imitating a natural tear-out without letting the tear go too far down the stem would be best. These's all sorts of articles and discussion about how trees manage to split their vascular system at unions without compromising strength, but the best way to see it is to tear off an inclusion fork, that is the exact point nature has desingated as the weakest point surrounded by the best regenerative tissue. Callus will be stimulated by flexure, so leaving a great big lumpy pruning stub will prevent flexure and wood development on the retained side.
It will look a bit like the dreaded flush-cut but in most ways it's the opposite, physiologically.
Hope you follow what  am suggesting and go for it and post pics now and in the future.
Thank you for that detailed explanation Jules.
Needless to say I had meant to deal with this branch years ago, but oops.:$ I procrastinacted.
I do not quite follow your instructions though.
Are you saying nick into the main stem just below the union to prevent the bark stripping down the stem and then pull the branch off with a winch?
To as best possible mimic storm damage.
Cheers
Marcus
Edited by difflock
