Lifted from a thread on the AARSE site
Pick the cat up and cradle in the crook of your left arm as if holding a baby. Position right forefinger and thumb on either side of cat's mouth and gently apply pressure to cheeks while holding pill in right hand. As cat opens mouth pop pill into it, allow cat to close mouth and swallow.
Retrieve pill from floor and cat from behind the sofa. Cradle cat in left arm and repeat process.
Retrieve cat from bedroom and throw soggy pill away. Take new pill from foil wrap, cradle cat in left arm holding rear paws tightly with left hand. Force jaws open and push pill to back of mouth with right forefinger. Hold mouth shut for a count of ten.
Retrieve pill from goldfish bowl and cat from top of wardrobe. Call partner in from garden. Kneel on floor with cat wedged firmly between knees, hold front and rear paws. Ignore low growls emitted by cat. Get partner to hold head firmly with one hand while forcing wooden ruler into mouth. Drop pill down ruler and rub cat's throat vigorously.
Retrieve cat from curtain rail, get another pill from the foil wrap. Make note to buy a new ruler and repair curtains. Carefully sweep shattered 'Dolton' figurines from hearth and set to one side for gluing later. Wrap cat in large towel and get partner to lie on cat with head just visible from below armpit. Put pill in end of drinking straw, force cat's mouth open with pencil and blow down drinking straw.
Check label to make sure pills not harmful to humans, drink glass of water to take taste away. Apply plaster to partners forearm and remove blood from carpet with cold water and soap. Retrieve cat from neighbours shed and get another pill. Place cat in cupboard and close door onto neck to leave head showing. Force mouth open with dessert spoon and flick pill down throat with elastic band.
Fetch screwdriver from garage and put door back on hinges. Apply cold compress to cheek and check records for date of last tetanus jab. Throw t-shirt away and fetch new one from bedroom. Ring fire brigade to retrieve cat from tree across the road and apologise to neighbour who crashed into fence while swerving to avoid the cat. Take last pill from foil wrap. Tie cats front paws to rear paws with garden twine and bind tightly to leg of dining table, find heavy duty pruning gloves from shed and pry cat's mouth open with a small spanner. Push pill into mouth followed by a large piece of fillet steak. Hold head vertically and pour a pint of water down throat to wash down pill.
Get partner to drive you to the Emergency Room and sit quietly while doctor stitches fingers and forearms and removes pill remnants from right eye. Call at furniture shop on way home to order new table.
Arrange for RSPCA to collect cat. Ring local pet shop to see if they have any hamsters.
Soldiers have not changed.
Edited by difflock
  • Haha 6
Just heard this off a mate but it’s probably old hat as I’m not so up on current jokes unfortunately……
Micky and Minnie Mouse are in the divorce court and Minnie’s lawyer says to Micky “so you say you want to divorce Minnie because she is a bit silly, I don’t really see how that is grounds for divorce”. Micky at the stand Micky says “no I said she was F*****g Goofy”.
