Clean the spark plug and put a little petrol down the bore never fails for me if there is a spark there. She may run a  few seconds but it will pull the petrol through if all the running gear is good.
Edited by topchippyles
2 hours ago, Stubby said:
If you get it running again I would use an Alkylate fuel and then you won't need to run it dry .
Alkylate fuel yes, but we always ran these things at 25-1, and still use 25-1 on the K1260 and K1270.
11 hours ago, stewmo said:
I am wondering if I simulated a choke, by blocking off the air intake somehow, it might pull through some fuel?
thats basically what a little fuel in the bore or in the carb does, i like to use a 5ml calpol type syringe and just pop it into the carb before putting air filter back on, runs a little longer than putting direct into cylinder
great idea.  I was in hospital recently (all fine) and you should have seen the kit that I rescued from being thrown into the bin. I got a variety of syringes up to 600m that I thought might be useful for emptying fuel tanks plus some long reach forceps that will be great for fishing out fuel filters !
Yeah perfect, I like to use syringes for measuring out oil to mix aswell.
the 5ml syringes seem the perfect amount to get a saw to fire off and run without flooding.
syrings also quite handy for priming a bar - use it to run oil down the groove and into the nose sprocket
Thanks for the info. Imagine we have calpol syringe somewhere for the kids.
otherwise a teaspoons worth will do by the sound of it.
Presumably you start with the throttle open?
