If you have then tractor, then yeh get a hydraulic splitter.
Look up ktm machinery, they used to be really cheap, not so much now.
Never used one but don't like the look of the blade on the oxdale
3 hours ago, kram said:
Yes I was tempted to weld the Stihl maul. I have this old 7.5kg sledge. It has done a lot of work, smashed up a lot of concrete.
That's not a hammer, this is a hammer.
Chain makers hammer. About 50lb, 23kg apparently.
The weld holding the blade to the shaft sliding part broke on mine in the first couple of weeks use if that helps🙈.  In fairness they sent a completely new splitter straight away... and the same happened!
I wouldn't touch one but they said it was a batch issue and they'd sort it which I'm sure they have, think I was just unlucky.  I moved onto processor so never bothered chasing it up.
But getting back to point yes fiskars x27 is a good axe to start with, can't go too far wrong lovely axe.
