Not a brand I’m familiar with. What will you be running it behind?
Most flail collectors will do a decent job on light grass and relatively heavy brambles. Its thick scrub or thick rank grass that will test them.
Edited by doobin
I've only used the rytec one. Which is really really good the only thing I find is they fill up really really quickly. Rytech was high tip so you could tip in right into a trailer.
I've mown long grass and light scrub with it..works well just don't smash up big stuff and they last quite well.
Yeah, my experience is with rytec and as you say their capacity lets them down. Omarv models carry quite more m3 but never seen them over here. I’ll be running them behind a Valtra t/n 174 or when required alpine tractor
Be careful about putting a 190 odd hp through the mower. Normally the gearboxes can take it but the PTO shafts can't and then deform.  You really want a thick walled star shaft for putting that power through it. Don't use a lemon shaft rated for about 70hp or it will break
I won’t pretend that I didn’t find this out the hard way!
Primarily I’ll run it behind smaller tractors however we get asked to remove larger areas throughout the ecology season so a more comfortable machine/cab would be great. Pto will be beefed up regardless so thanks
Where as I knew it was theoretically possible I was surprised when i saw it the first time.  I actually went through my photos to try and find the torn lemon shaft but I couldn't. It wasn't a big hp disparity form tractor to shaft either.
One thing that is worth considering is that if you can fit and handle a bigger machine as I'm going to guess a 190 is 1.9m wide. I know a 1,9m on a alpine is big but on a valtra isnt.
I've always run mowers between 1.8 and 3.2m most conservation mowing I've done I've always kept it 2.3m.to 2,5m so it covers the back of the tractor.
There's a Dutch brand called Schouten, they make an in between size flail collector, designed like a forage harvester but with a flail or scarifying head. Well put together machines, but you'd need to have work for it. They're not cheap to buy.
Here's a picture because I don't think I explained it too well.Screenshot_20231231_164728_Chrome.thumb.jpg.89a98047cc20f68dd8f4d5f5a0c082c0.jpg
Trilo do a similar thing. They a massive one for mowing runways and airports. I've only seen the sucky for leaves on golf courses but Enfield council have one that mows as well.
