I'm not actually a tree surgeon, just someone who has to cut logs occasionally but hopefully it's OK to post this question.
I have a small Makita electric chainsaw that I've had for a few years, pretty light use.
I went to sharpen the chain yesterday and found that I couldn't turn the chain by hand. Taking the bar off, I found that the drive sprocket is very stiff: I can just about turn it using a pair of pliers but not by hand.
The electric motor still turns the chain OK. Although I have to say it doesn't seem to be cutting as well as it used to, even with a sharp chain.
Should I have a go at taking it apart and seeing if there is something I can lubricate inside and how easy is that for a reasonably competent DIYer? Is there anything else to try? Thanks.
You can always ask, whether you get a sensible answer.....
I have Makita top handle saws, the sprocket comes off easily. It's not a clutch drum as on a petrol saw but there's a brake drum and band which can all be stripped out and cleaned, if you've never done this it is probably jammed up with sawdust. Think you just need a PZ2 screwdriver.
Taking the brake spring out was a bit more annoying but still possible. Have a careful look at the parts diagrams you can find online to see the bits.
26 minutes ago, monkeybusiness said:
How does the chain brake work? Is it automatically on when not cutting?
Most mains electric or battery chainsaws have a cut out switch rather than a traditional chainbrake as you will very quickly burn out the motor and strip nylon drive gears if a brake band was used with power still going to the motor with it still switched on. Once the brake lever is activated it cuts the power
Edited by pleasant
