Maybe your over tightening the chain causing it to stretch prematurely.
I cut a lot of firewood, sharpening regularly so probably 30m3 between chains, but never had one stretch much.
It's usually lacking teeth rather than adjustment.
5 minutes ago, Rob Stringer said:
Thanks for the replies, its a problem i've not had before in 15 odd years of regular use so a bit mystified..
Is that 15 years of use with this specific chainsaw? Have you changed the sprocket recently?
Stihl bio isn't the best for oiling. I see quite a few saws coming in that use it, and the chains are gummed up and really tight that you can't move it by hand or hanging of the bar. I've seen saws run with standard veg cooking oil that are in a better state.
