Hi! The flywheel on my Husqvarna 560 came loose while sawing, and the flywheel broke. The splint that goes on the crankshaft axle broke off so i need a new flywheel. My question is, does a flywheel from Husqvarna 550xpg fit on my 560?
By " splint " do you mean the flywheel key ?  Any way ADW will know @adw
The answer is no, plus if it’s a G then it has the generator magnets inside so needs to be a G flywheel if you want to continue with heated handles.
I am well aware the taper holds the flywheel, however the chance of lining  up the broken key in the keyway exactly is pretty slim, you will end up with the saw ripping your fingers out of there sockets.
