i run motul 800 at 50:1 with super petrol so as to only have E5 not E10, used to use esso synergy supreme as it had no ethanol content but that changed in september of this year
Do you reckon it's this shite newer petrol that's screwing up equipment more than the oils we use?
Stale fuel can cause all sorts of issues, however in my humble opinion inadequate maintenance is a big cause of premature failures, poor chain sharpening, blocked fuel or air filters, allowing the starter cover grills to block ( this is basically a stationary engine, so all cooling air for the cylinder comes via the cover).
well i wouldnt say screwing up but ethanol degrages rubber at an increased rate so fuel lines, carb diaphrams etc wont last as long but another thing is the ethanol attracts water aswell which makes stale fuel even worse as it could have absorbed water if it wasnt in a completed sealed container
agree big time that proper maintance will probably make a bigger difference than oil a vs oil b providing that theyre both synthetic and a known brand...
Normal 50:1 Aspen for most things, aspen topped up with two stroke oil to 40:1 for milling and 40:1 with super unleaded in the new strimmer (only because I use it so much in the summer. I’ll strip the carb at the end of October.)
i currently use Oregon semi synthetic FD two stroke oil and the cheap oregon mineral bar oil. Both seem ok. For the aux bar oiler on the chainsaw mill I use whatever old (unused) oil I can lay my hands on - veg oil, engine oil etc.
