1 minute ago, Joe d said:
I would think that's a definate to make it more awkward 😂
Don't give them ideas, they'll be using a mixture of BSP, jic and left handed thread adapters just to mess with your mind!
Its a twin pump on these chippers, one section of the pump does most of the work (the feed rollers and one tracking motor), the other pump section is only ever called for when tracking. You could easily eliminate the pump by swapping the pipes over on the pump, you may need to snip off a few cable ties but it would be a quick and easy way to see if the slow track is then on the other side of the machine.
Bob
When was each blow off circuit tested? They could be running out of balance or as a previous post alluded too, one pump might be running stronger and a meter heeds to be used!
