57 minutes ago, spudulike said:
You can either bypass the CAT by drilling its mount plate if you can get to it or do a cut in the muffler box closest to the cylinder and Louvre it....a bit like the old MS260 used to have. Simple and effective. Don't forget the carb retune.
Thanks. There's already a bypass hole in the cat mounting plate as it happens, but I don't really want to mess with the cat or retuning yet. Happy to just have the saw working, probably without a spark arrestor screen!
23 minutes ago, bmp01 said:
It's a one way trip isn't it ? Do what ever is easiest with the tools you have.  Drill and dremel work for me when opening exhaust outlets, removing dividers or spark screens etc.
Pair of pliers and a small hook to remove thick wire ball from a chinese top handle exhaust, that wasnt catalyst wire but it wanted gone all the same.
Yep, one way! Drill and Dremel I have, let's see what happens... Thanks.
Worth noting, in theory it is possible for the engine to suck loose debris from the exhaust back into the cylinder, although even less likely if it's t'side of a catalyst. Use an air line or what every you have to blow out swarf or grinding dust from exhaust. Better safe than sorry.
Just bin the spark arrester or drill it out.  I've adapted, fixed, or changed a few exhausts and the engines run fine afterwards.  If you are worried about the engine running differently, check the tuning.
My thoughts are if your spark arrestor is getting carboned up it will glow and run hot . you can either remove and clean it or just remove it completely as it is only there to meet the criteria of dry area cutting where as when did you see a dry day in England's fine woods ?
