7 hours ago, AHPP said:
For the cost of one fencepost and two pegs, just try it. This will spur me on to trying it too. Someone of this parish suggested similar a while ago. Not needed one yet but I have a spare fencepost so why not.
Other thoughts: use more bags and fill them less; grab the bags like Dan said.
Why buy a fence post, any good piece of timber the right size would do.
8 hours ago, Mark Bolam said:
That’s exactly what gave me the idea Paul.
Doobin I know you’re right, but I’m after speed with minimum ****************-on.
Alex, 50kg bags I can still hand-ball.
Even up to 100, which is why I got hernias.
I’m taking chocca bags full of wet conny rakings and dust.
In that case I'd just drill a couple of 12mm holes in the bucket grab corners. When you want to lift a bag, an M12 bow shackle in each corner, each holding the two loops from the sides of the bag.
This will give you a touch more lift by being able to crowd the bucket right back, although at the expense of leverage. You could always drill another pair of holes further back.
Even a man of your limited fabrication abilities should be able to manage that.😘
Edited by doobin
10 hours ago, Dan Maynard said:
I just imagine you'd tie the bag off then grab and squeeze the whole thing if it's just rakings, but I just had fizzy water with dinner so obviously not in a thinking mood.
That’s exactly what we do Dan.
One makes sure that the bag isn’t rammed full, so it’s got some “squashiness” in it, fold the top over a bit, then just grab the thing with the Klou timber grab.
You’ve  also got a much more compact load to put onto the truck especially if you’ve got ladder bars across the top or a roof.
Slight problem is I haven’t got a bucket yet….
I was that drunk I didn't read the post properly- was assuming bucket grab, because THE BUCKET GRAB IS SUPERIOR TO THE LOG GRAB FOR BACK GARDEN TREE WORK!!😆
But as you have the log grab, yeah, a short chunk of telegraph pole with a suitably sized and fixed hook should be fine. Your biggest risk will be the timber splitting along the grain with the forces.
DON’T SHOUT AT ME REUBEN.
ALEX AND I BOTH KNOW YOU’RE WRONG!
Had a piss about tonight with a fencing stake and Alex’s idea has legs in terms of lift height.
I’ll have a play with some straight timber at the yard and report back.
