17 minutes ago, outonalimb said:
Where exactly are you getting this crap from?
Its not crap,  it might be crap in your opinion I've researched quite a bit on two stroke oils and their ratings, maybe you should too instead of your insulting comment. I'm not looking for arguments at all just honest opinions from which I've been hearing honest answers so far.. until u showed up. If you've nothing positive to say don't bother..
This is just another totally pointless oil thread exactly like the hundreds of other oil threads , which had you read, might have stopped you posting yet another one. I don't care what saw you use it's all been covered before.
21 hours ago, agrimog said:
interesting topic, but no one has asked the vital question.....what effect does more oil have on the a/f ratio....easy, it causes a leaner mixture....leaner mixture runs hotter....hotter 2 stroke= siezed engine, stihl, hursqvarna, echo, etc, have all set there carbs up to work the f/a ratio as close to perfect as they can based on a 50-1 ratio of oil, if you run less oil, the mixture gets richer, and effectivly is the same as running on choke...fouls things up, the more oil you run, the leaner it gets and lean runns hotter and hotter till it siezes, or worse, melts the piston, anyway, your saws and strimmers, do what you want,  oh and the more ethanol, the more water it absorbs, the leaner  the longer it sits
Aw crap, here we go again, the more oil, leaner running rubbish. Not being personal but it is utter tosh!!!
  • Haha 4
On 11/03/2023 at 18:13, spudulike said:
A little note, for Gods sake don't say that 45:1 weakens the mixture as we have discussed this at length and don't want to hear it all again. I would rather go down the fish based responses again......perhaps I should have said for "Cods" sake!!!!
I've been waiting for you to pop up!!
