The Palax has been very faithful since I bought it twenty five years ago but recently the ram auto return has been playing up
We can split ten pieces and it returns every time then it refuses maybe once maybe five times maybe for the rest of the session
It seems simple enough as there are plenty of adjustments but we had a real good go at fixing it today to no avail
no 1 is looking down at the spool valve which operates the ram .  The plate hits the rod coming up from the spool and the adjustable stop on the next picture is hit by the ram going forward and triggers the return by flicking the rod the other way.  The adjustment on this stop limits the ram travel so that it doesn’t hit the knife
The next picture shows where that square rod is gripped by a bolt under the plate
I have tried adjusting all these points but it doesn’t make any difference .  The ram travel quickly when working well but seems to be slow when the fault occurs as though the spool valve has only been partially opened.
I cannot understand why the ram will not trigger the return every time as it hits the stop quite hard and the spool is the kind that clicks into either position, you do not have to hold it there.  A light tap with hammer or boot on the valve is all that is needed to make it return but this becomes tedious in a working day
Any suggestions would be welcomed
(apart from just use a bloody axe Billhook!)
30F625F7-7F7E-443E-B06A-AFCE9D413241.thumb.jpeg.5b68d16e7155c27dedca1fa8660f01a0.jpegC2D81532-96CF-43AC-8924-E02AB6B3AEB2.thumb.jpeg.e19f53993e7372bc4b1e8a256635d79e.jpeg2323CFED-DC97-4ADF-81D1-F4E817B3D730.thumb.jpeg.892ca933a9ad559f11985ec8f89bdff2.jpegA768E306-C806-4AFC-B7CE-6E9E9966BFD8.thumb.jpeg.374e69ec9ced1011d6913e8d5dfcd8a6.jpegC3646641-EA3E-4B8E-945A-24C6047FD789.thumb.jpeg.30783f26b299c8ded837fab11e8b4621.jpeg
This sounds pretty obvious, have you had the valve apart to see what's happening inside ? It's 25 years old and might need a little TLC, some Jizer and a blow down wouldn't hurt it.
How long since a hydraulic oil change and any debris in the filter?  Sounds like the spool valve is got something sticking in it. you could replace it or strip the valve down and see if anything is worn inside.
Clean all the shit out from everywhere and then spray down with some clean oil and see if you still have a problem. Only time I had a problem with similar symptoms was due to woodchip not allowing the full travel of the control therefore not allowing the auto return.
Do you think I should suggest the same to my wife to improve things down under?
Definitely, it wouldn't hurt to freshen up a bit.😉 Womn lovew the smell of Jizer.
Good advice from you both, thank you
  • 3 weeks later...
This. When our Jappa has the same issue it's due to crud in the slot at the end of the ram stroke.
