I am just about to undertake some conifer thinning and just doing some figures and calculations.
Could anyone give me some figures please? What i am after is either a rough weight per log or how many logs to make a tonne.
This is all for SS and some NS first thinnings, low yield class, roughly planted 96-99.
Pulp
Stake wood
Pallet
 I doubt there will be much pallet tbh but no harm having some figures for second thin.
Ok so here is some figures i got using an online calculator which I think isnt too far off,
So
pulp 3m >7cm im getting 28kg
stake 1.6 >8cm = 6.5kg
Pallet 2.5 >14cm = 24kg
Sawlog 4.9 >20cm = 83kg
Sawlog 5.5 > 24cm =118kg
if anyone could help tell me if these are good enough for ball park that would be great; more madness to follow!
Edited by Treemover
So
I think some of them weights are way off , i will have a working out session and post back
Thanks openspaceman, I have that book and I used to prepare harvest sales or SPs years ago, but as mills pay over the weigh bridge it was more per tonne weight than per m volume. Still thanks for the tip, and I'll give those figures a run two, just for pig iron. Appreciate the reply.
So
Your weights are a bit out ,
2,5 14cm M/D 35kg
4.9 20cm M/D 142kg
5,5 24cm M/D 230kg,
If you are doing this by hand ie man and a chainsaw the fence posts are just not worth doing, we havent done any fence posts of that size now for near on ten year as there is just far to much time involved in it for half a days wage, just put all the smaller timber in to the chip stack far easier to handle and stack than the small short stuff,
42 minutes ago, Dan Maynard said:
We're his original figures dry wood? I was thinking a 20cm log at 4.9 would be harder to move than 83kg.
It's a thinning job so fresh felled ,  it wo t be dry by a long way,,
