Petrol Saw Bench
Cosmiccrofter
Anything is possible providing you have the power and flow to match the application and the ability to make it fit.
Only real problem is your adding complexity, ie another thing in-between to go wrong. Plus you'll probably require active oil cooling if the flow is high enough Vs just using an old tractor.
