7 hours ago, john87 said:
100: 1 will kill it, make no mistake about that..
I can tell you EXACTLY what is wrong with it, the fuel you are using.. Tip the shitty unleaded out and buy any one of the premixed alkylate
john
100:1 will kill it ? Depends on the oil .  How will EXACTLY the " wrong " fuel cause there to be no spark ?  Await with interest 🙂
Pretty sure his remark was directed at Grassy dude's comments about his one('s) being very fussy about fuel mixtures and erratic behaviour unless it's just right.
9 hours ago, Daniël Bos said:
More confused.
I swapped the coil with an ms880 one (coz biggest flywheel in my 2t collection)
No spark.
Tried a (4t) lawnmower coil.
No spark.
Tried the AS coil on said lawnmower.
No spark.
To rule out a break in earth continuity due to my JB weld, I put on a separate earth wire straight to the plug threads, no spark
Flywheels can stop functioning, but then I'd expect a weak spark?
Also, it sparked really well for a bit when I got it going at first, followed by absolutely zero spark, which makes me think coil is bad, but then why do I get no spark from the other coils either?
Aaaaaaaaaaaaaaaaaaaargh!
I'm pretty sparsely thatched already, otherwise I'd be pulling out hair at this point
These things can drive you mad , I’m sure  you have tried all the obvious stuff  you seem clued up, dose your coil mounting bolts sit on nylon spacers I seem to recall they did, and they weren’t a common plug  you fit them without the cap , do you have a main agent local to you ,l could ask the guys I bought mine off for any ideas if you have no joy,
Missed the bit about spark as i did not read through whole thread. HOWEVER, in the very first post the poster states it runs but roughly.
So.. Does it have a spark or not???
john..
john..
It didn't, then it did for a little bit, then the spark died and now I can't figure out why it doesn't spark without throwing money at it.
Edited by Daniël Bos
Spelling
Perhaps it is just knackered.. Try this as a final test, it has never failed me..
Put in brand new fuel. Take out the plug and heat the end bit literally red hot with a blow lamp. Put it back in as fast as you can and try to start the thing. 99% certain it will go first pull..
john..
john..
A final test of what exactly?
What would doing that tell me?
