It looks like your H screw is wound a fair bit out. Wind it in until LIGHTLY seated and unwind 1.5 turns and try again. 1 turn is usual but am building in a bit of safety until the saw is running better.
The H screw is the one on the carb furthest from the engine!
17 minutes ago, adw said:
Does  the machine have the spark arrester muffler? If so is it blocked?
have also taken muffler off and cleann around gasket and new gaskets will try making an wider opening in morning
The back fire suggests the ignition timing is incorrect and that the flywheel has spun round on the crank and sheared the key but generally it wouldn't run when this happens.
It is however, worth pulling the flywheel off and checking the flywheel, especially if you can do that sort of work.
The over revving - in your first video, the saw sounded pretty strangled and no sign of it over revving, when does this happen and if you turn the H screw anti clockwise, does it stop over revving?
Over revving is generally caused by an air leak or an incorrect setting on the H screw....just so you know.
The 350 is prone to leaking air between the lower engineering plastic cradle and the upper crankcase. This wouldn't cause the fuel to come out of the inlet but would cause over revving.
Strange you have over fuelling and over revving together as too much fuel means lower revs as can be seen in the first vid.
Put new flywheel on and still no luck not as much fuel now but still over reving
