Hi all,
I have a lovely 395xp which has run for me for a few years with irregular use. Home milling and firewood mainly.
I am really careful with my fuel mixing 33:1 and emptying when finished.
The saw ran for an hour or so last weekend and wouldn’t start again. A local dealer says this pot and piston are knackered and quote over £500 to sort it.
Does anyone have any recommendations?
Shall I repair the saw? Or chop it in for a new 661 or similar.
Has this happened because of the fuelling issue or is it just general wear and tear the saw is a 2003 model.
Thanks in advance
  On 19/05/2022 at 15:44, BigRon said:
Hi all,
Thanks in advance
Expand
Have a word with spud i would be leaning towards getting it fixed but i would do it myself.
spudulike
Edited by topchippyles
I would think you may have had an air leak causing it to nip up . Also good quality synth oil at 50:1 would be my choice . As above , I would also get it fixed  ( and the air leak if there is one ) but I would go OEM on a good saw like that . Also , if only used infrequently I would go for an alkylate fuel like Aspen or Husqvarna equivalent .
Edited by Stubby
Sometimes saws develop a big issue such as a split impulse, leaking seal or split manifold. Sometimes you get a partial blockage in the carb. Sometimes it is just a poorly adjusted carb. Sometimes it is just a mix up of a few of these things
395 cylinders are pretty strong and can often be cleaned up with acid, abrasives and a light hone.
If a decent piston is fitted and the engine pressure tested, the carb serviced, the fuel line/filter checked and the tank breather checked and finally the carb is tuned to ensure the carb stopped the saw over revving.
Do these things and you get a saw that is set up correctly and you are an engineer.
Do a few of them and you are a gambler!
Expand
All day long !
Thanks for the replies. My mechanical skill is basic to say the least, Steve has politely said he’s not taking any new work on does anyone have a recommendation for somewhere or someone to have a look?
Expand
Put where you live will help other members help you.
Read more
