Recommend me a logsplitter
Cosmiccrofter
I have a 15 ton splitter run off the tractors hydraulics which works very well.
However, to free up the tractor, I would like to run a splitter off my MF 35, which hasn't the hydraulic capabilities of the bigger tractor, so what I want is a hydraulic 15 ton splitter run off the pto, preferrably with auto-return, but there doesn't seem to be much choice.
Any recommendations?
Or another thought, what would I need partswise to convert the current splitter to run off the pto?
Check out AMR range from fuel wood they do a PTO 17t splitter for less than 2k ours has been good for the money although the return springs don't seem to last they can be bodged .. you get what you pay for .. we run it alongside a Posche which is a different league but triple the price.
I've just had a quote of £2,880 plus vodka and tonic, for the ARM, so not very cheap, but I do like the look of it. However, I may have to go down the "adding a pto pump to my splitter" route.
Can the ARM be "converted" to one hand operation, not that I would ever consider doing it!
Edited by Cosmiccrofter
Hmmm they will have gone up a bit but you still won't find anything commercial grade and decent for less.
Possibly it could be converted 🤷🏼
