That saved me probably 2 days.
Simona’s having a stand for her baby stuff at a show on the weekend. Making some display stands for her. Joinery is a bit rough round the edges to put it mildly but it will do the job and should look nice once waxed
If you are screwing two bits of wood together like that, make sure that the piece of wood the screw goes into first has a clearance whole and not a pilot whole. Eg. A whole 0.5mm or 1mm bigger than the screw diameter. This will ensure that they pull together tight and don't get screw trapped between them keeping them apart.
Nice job though
Nice job though
Thanks for the tip. Yes I’ve been having that exact problem
6 minutes ago, muttley9050 said:
If you take them screws out and redo you will probably close them gaps
Your advice is unfortunately a few hours late on this occasion
Nice job though
Hole hole hole. :D
3 minutes ago, muttley9050 said:
19 minutes ago, trigger_andy said:
I was talking about a whole hole. Not a bit of one.
Well this is clearly Steves first time so I can see why you needed to clarify. :D
The dowel grain is supposed to go the same direction as the main grain stevie
Edited by topchippyles
