Husky 346xp piston cylinder issues
Frazer Burley
Ah...how about this, piston ring pin comes out, gets rammed between the piston crown and squish band, con rod gets bent......very possible, what does the squish band and piston crown look like? Any indentations?
Was thinking similar, something being partially lodged causing excess pressure resulting in the rod being bent. But also the fact its worn the gudgeon pin on one side with needle bearing indentations evident (think thats what OP said) could suggest the main bearing is worn allowing the rod to run on the tilt maybe. A pic of the rod length ways might shed a bit of light
Piston crown being the top surface? No indentations or dings.
squish band? Piston ring? No dings just fused to piston at one point
38 minutes ago, Frazer Burley said:
Never seen one like that, looks like the gudgeon pin is soft and it has had a hard impact.
Strange on the piston crown. I would have expected damage somewhere from where it ended up. May have been lucky and ended up in the exhaust.
It would be worth inspecting the big end cage - the normal way is to lubricate it, shove the cage to the left, the rod to the right and hold the rod in place and rotate the cage looking for cracks, missing cross sections etc. Repeat on the other side of the rod and then a final check - get the rod in the middle of the big end, push the small end hard to one side and see if the rod still rotates cleanly on the big end by moving the small end to and fro. If it feels notchy, something aint right. A bit subjective but it is my go to test.
