What Tree Shear Works Well With Avant 630?
Chipperclown
My thinking came down to 2 key points.
Firstly - I specifically did not want a cut & hold function because it was my assessment that this could / would lead to an unacceptable likelihood of toppling the machine over. With the best will in the world, human nature is likely to lead to the temptation to push the limits leading to catastrophe. It is a relatively narrow wheel base after all.
Second - I did want a rotator function for the likes of hedge reduction and the ability to cut at any angle rather than just upright.
So far as I could see, there wasn’t a grab + rotator function so - for me - rotator was more important than grab although I like the functionality of the Avant variant using the grab part for grabbing.
It’s horses for courses I guess. Like any tool - great in the right circumstances.
I got mine from Exac-1 all the details are on their website.
2 hours ago, Stephen Blair said:
For grab and rotator you just need enough hydraulics or an electro valve set up.
  To cut and not grab just is not in my thought process.  It would create more work, the cuttings the easy part, the lifting is the best thing to reduce manual handling.
You can still grab / pick up cut stems by just ‘pinching’ the tree in the shear but I know what you mean. I’m happier cutting and letting it drop rather than cutting and holding on - means I can cut bigger and further away without risk of going over with it.
