Needed a new workbench for the new workshop, really just something til I build a Roubo but as that could still be some time away I thought I’d build a strong but simple bench out of the first tree I milled. So the top and legs are Beech and the rails and slats are Oak. IMG_4033.jpgIMG_4044.jpgIMG_4052.jpgIMG_4074.jpgIMG_4137.jpgIMG_4079.jpgIMG_4177.jpgIMG_4178.jpg
  • Like 19
9 minutes ago, Con said:
Too good. I'll have it in my dining room,  when you've finished with it😂
Funnily enough the missus said the same thing. If I manage to look after it I might move it to the Cabin I’m away to start on. Well, when I say start on I mean start milling the 6” Beams.
I do like that; suits the location very well. I think I'd have made the top a bit deeper, but that's about all I'd change.
I’ll be doing the next Bench in 5” thick. This is 2.75” Beech Slab. It’s plenty thick for my needs.
By deeper I meant the top, so you have a deeper work space. I think the thickness of the top is just right.
Ah yeh, it’s 600mm wide. That’s as wide as my Mill can go. But I think it’s wide enough. It’s the same width as the plans I loosely followed.
