Hi, just got all my own kit and was wondering what was the best way of cutting my prussiks up, can any1 help or send me a link to a web page please.Thanks
Cutting up for what? Sharp knife?
I see now! If you haven't got a got knife use a blow torch and a large pair of scissors, cuts and seals the ends.
Edited by Paul Smith
I like to wrap a section in insulating tape, and cut through that with a sharp knife, then heat it. Also worth remembering that some of the more modern heat resistant fibres don't melt, they just charr and so you will need to tape things like OP and Bailout.:001_smile:
Insulation tape and a normal knife!
The hot knife/heat seal method is fine for short cordage but can keep the milk in a longer line. Insulation tape doesn't grab the core so it all just falls off the end.
If money is no object. Buy a hot knife. About £100 on Honey Bros website I think. If not, really sharp knife to cut and use a lighter to seal. Hope this helps.
( Welcome to the forum)
Rope Cutting Hot Knife
NEW DRAPER TOOLS 100 WATT SOLDERING GUN IRON KIT SOLDER on eBay (end time 13-Feb-10 11:36:38 GMT)
thats similar to what i use and adequate and good for occasional use
at work we have the proper expensive one like honeys sell
but not justifiable for occasional uses imo
I can help you out with stuff like that mate, I am assuming you're the same Deni that did a day for me last year, just saw your other thread. I will bear you in mind if I need an extra pair of hands mate, things a bit quiet just now though.:001_smile: If you want to meet up while we're working in town sometime let me know, I'll be able to help with knots and hitches and stuff.
