Sign in to follow this
Spideylj
Fencing Around TPO Tree
Something a bit different!
I've been to a clients this morning to look at a Lime tree that lies on the border of the property.  The client wants to fence around the tree but the post will be directly in the roots of the tree within centimetres of the stem.  Has anyone come across a fencing system that will allow the fence to go around the tree without digging posts in?
Share this post
Link to post
Metposts are better than digging but it's best to probe for suitable post positions first and use a fencing spec that allows post positions to be varied.
Share this post
Link to post
22 hours ago, woody paul said:
What type of fence have got to put up.
It's concrete post and panel but with no posts close to the tree.  The panels basically flap about.
Share this post
Link to post
Yeah, that might not be a bad idea.
Share this post
Link to post
We have completed a number of jobs like this where we airpade the post holes to find clear space for the post to be concreted in. Obviouly it works much better with closeboard fencing as you have some adjustment either side to find a clear path
Share this post
Link to post
Thanks
Share this post
Link to post
This is interesting. Does it take a long time to airspade the holes? What depth can you get down to? Or do you just do the surface layers where roots are most likely to occur?
Share this post
Link to post
Depth of the post then you avoid the gas mains n fibre cables 😉 K
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
