Not before October here and cannot light it as I've just cleaned it out, swept the chimney and put the stove on its back to free up the air control leers which jam up with ash over time.
Also spent half a day fabrication the first of two hot air manifolds to direct some heat into the adjacent room after passing through a duct under the stairs and a 150W ventilation fan.
I tried it last year and it worked well, albeit the fan is a bit intrusive, so I decide to engineer it a bit better.
That sounds like a really good.idea. Got any pictures?
Read more
This is the manifold, it's made from an aluminium extrusion I have had for years. I tried to anneal it  but some of the tabs I tried to bend as locating lugs broke. I only had a 50mm concrete core drill so that hole is a bit messy. It now locates over the convection vent with a tab at the back and one into the front of the slot, slightly sprung to hold it firm. I only have a DC TIG/stick welder so cannot weld it up but I don't think that will matter much. It took me about 4 hours of fiddling, making the mirror image one for the other side should be quicker.
2" flexible exhaust I had used last year carries the hot air through the brickwork and then down to floor level under the stairs to the fan.
I'll stee how it goes and then do any modifications before painting it all black with car exhaust paint.
5 hours ago, Big J said:
Yup.
We're in Sweden next month. We might possibly buy a house when we're there, we have a tour of the school the girls will go to, meeting a few different work contacts, have started selling machines/vehicles and reducing outgoings and commitments. It's rather liberating, and nice to have the time to plan. We rushed moving to Devon because of our older daughter starting school, with the whole process from the decision being made to moving only taking 6 months. This time, we'll have had almost 3 years by the time we go.
Fair play to you J - very best wishes for future success 👍🏻
Thank you. That looks good. Did you choose aluminium for its excellent conductivity? Actually, I guess you are gathering the heat predominantly via convection, is that right?
Very impressed you managed to cut that hole with a core drill!
No I chose it because that was what I had to hand and I only had to do a few hacksaw cuts to re-purpose it.
The stove has a double skin which heat rises through and normally gets emitted into the room, this device should pick that up and divert it into the next room as well as be heated by the top surface by conduction.
Yes that was a lazy mistake, I should have chain drilled the circles.
I need to get some wood from the stacks, split some kindling and sweep the flies.  Hope to not need it for a few weeks yet though
Sweep the flies? It's normally soot that people are trying to get rid of. [emoji12][emoji23]
