Not only can you quarter a log with this mill - you could mill the quarter sections with it as you go [not done here as they wanted to load onto a bandsaw].
Looks great Rob. Bit of a faff in set up but great result.
Wouldn't it have been quicker to just half it on the first cut or were you worried about a longer bar being less accurate
Yep I guess you could but the idea of this method is more that you can mill a larger log with a smaller saw. So with this one you could not do it with an MS660 but using this method you could.
To halve it you would have to have a big horizontal set up..
11 hours ago, trigger_andy said:
Clever stuff! More kit for me to drool over. :D
Yep the Intersect mill is very under rated and lots you can do with it!
2 minutes ago, htb said:
Not me Andy, I'm still using the alaskan I bought from you.
Hows it going with that?
I found a 36" Chilaskan in the garage that Ive never used and forgot I even bought. :D
