tracked hydraulic winch for sale
mattyboy
Careful with these winches they outpull there weight if you are not careful. look at the picture the winch is unsetting the blade/anchor the line pull should be straight, the angle in the line is pulling the front up it could do with a lot more weight.
Edited by dumper
Spelling
Never had a problem with what you are referring to, you can put blade down hammer the spikes in, tighten the fly bolts on the back and she’s solid as long as ground isn’t pure slosh. You can also put a large strop around body of dumper and around stump/tow ball of truck/anything to be 110% sure
