Can anyone tell me more about the 'blowing bubbles' test to confirm well-dried firewood.?  I have seen two wonderful videos on this but I cannot get the same effect.
I had some ash logs which were less than well-seasoned and put them in an oven at 100 degrees C for 24 hours.  At the end of that time, and when cold, they passed every test for dryness:  substantial loss of weight, radial cracks, bark lifting a little, clacking sound when knocked together, previous resinous smell gone - and moisture meter reading at 10%.  (I've only measured the moisture externally for the time being, with a pin meter) .
But when I try the washing up liquid test, I only get one or two tiny bubbles after blowing very hard  -  nothing like the videos showing apparently effortless blowing with a thick layer of bubbles emerging at the end of the log.
Any thoughts gratefully received!
The only video I have seen is the Aduro stove one at 1.24 minutes in
  • 3 weeks later...
Interesting, I'll have to look that up
Have you tried setting them alight?
It's quite apparent when wood is wet.
Edited by Mark J
In one of the vids the guy demonstrated the dryness of sub 18% and over 25% (I believe) all from blowing bubbles, not sure how accurate that but if its correct to any degree is seems far quicker than setting up a wee camp fire whenever you wanna check it out.
Alright petal...
You can get a moisture metre for not many quids.
I know that chip boxes in tree trucks get pissed in, a lot.
I'd be reticent to be putting my lips on any logs, but each to their own.
