15 minutes ago, Stubby said:
I can not comment having never used them other than to say the reports from people who have used them  varies  considerably .  Differences like inconsistent hardness of cutters ( some you cant touch with a file some you can )  chains stretching ( not just after first tension )  some with no complaints at all  . This leads me to conclude ( rightly or wrongly ) that the quality control is non existent .
They are a budget chain and cannot expect perfection.They are fine for certain jobs
I don't expect anything , as I said never used them . It was just an observation .
Expectation in general to all worldwide (GLOBALLY) who use rotatech chains if that clears up any confusion.
Edited by topchippyles
But given that I order randomly whenever I run low of a certain size, you'd think I'd have got a duff one by now?
Fcuk knows .  Buy a lotto ticket !😁
People expecting a rolls rocye performance out of a skoda. Aint gonna happen but both will get you from A-B
I have used them on a chainsaw & two processors.
They do seem to be slightly more stretchy on the first use. After that dont really notice it.
They cut fine out of the packet. I sharpen with a grinder so dont know re how hard some teeth are.
Put one on my latest processor to do a job & then left it on to do the next. Only adjusted tension once. Not sharpened it at all & it has done about 30 tonnes of hardwood. I have another job with it this week doing softwood & I wont be changing the chain unless it shows signs of loosing its edge. I am expecting it to do 15-20 tonnes. After that I will sharpen it regardless.
On my smaller processor I tended to change the chain every job (even big brands). Partly I think due to it using hydraulic fluid to lube the bar creating more wear / heat.
I think I must have used about 100 rotatech chains now (just bought another 40 for this year last week) and I don't remember having any major issues.
I get the odd hard tooth but I got that with Oregon before. People have their favourites but if I handed someone a saw I doubt most would know which chain it was running.
3 of us confirm the same so nothing wrong with chains. I use a grinder so maybe those who have problems hand file but myself like a hard steel toothed chain
Thats an absolutely shit design isn’t it? How much would a dedicated reservoir have added to the cost? Bugger all, not to mention the chance for cavitation if a careless op lets the level drop too low.
