7 hours ago, daveatdave said:
did they replace the original mustang engine with the merlin engine that was used in the spitfire
The Merlins were made under license  by Packard for the Mustang .
Yes but they also radically redesigned the dimensions and accuracy to make it much easier to assemble without skilled fitting, this upped the ability to produce them quickly and cheaply, they also fitted the pressurised carburettor to prevent problems transitioning to a dive.
The original mustang engine had poor altitude performance so the two stage blower of the merlin enabled it to stuff more air in at height.
Apart from its flying characteristics it benefited from range due to carrying brtish designed disposable paper mache drop tanks. The spitfire being a  pure short range interceptor early in the war and developed worse characteristics as it was upgraded into a much bigger aircraft in later versions.
In the meanwhile the americans were developing the  ultimate piston engined fighters with range, clout high hp radial engines and robust armour  like the Vaught Corsair and older P47 that may not have been quite as agile but could pounce on any opposition in numbers with only a few hits from the lager calibre  ensuring success.
Not forgetting the laminar flow wing, which enhanced the dive speed and the ability to convert all that potential dive energy back into a climb, so rather than mixing it like the WW1 dog fights, the aim was to surprise the enemy diving from a height hopefully with the sun behind, letting off as many bullets as possible before diving through the enemy formation and recovering your original height ready for another attack.
The other fantastic fact about the Mustang was that from conception to prototype was 102 days.  The American "Cando" ability demonstrated by the North American Aviation Company
