25 minutes ago, Justme said:
Chargers as much less efficient on modified waves than sine wave.
More heat produced per watt consumed so less in to the battery.
The AL500 is also not just a dumb charger like for your car bat.
I agree a small genny seems the best way. Also good for the kettle ;)
My earlier calcs were based on the 300s battery.
Yea it would be more efficient on a pure sine wave but ~£200 more efficient? Unlikely... I would say that compared to some of the skyrc and turnigy chargers used in the model world where you can set ramp rates, cycles and a whole manner of things the stihl charger, whilst containing a microchip which can sense voltage/temp and charge rates it's still a relatively dumb charger and is on the same level as the Makita chargers which can take a fair amount of abuse and won't be effected by a slightly distorted wave. That being said, you will get more efficiency out of a pure sine but it's debatable if it's worth the cost. The battery won't see any difference on its end anyway
if he cant start a petrol saw then a genny will be worse!
5 hours ago, Khriss said:
.. not just me then, bloody fingers are murder lately, were fine last year  🙄  K
Bashing your bishop too much Khriss 🙂
Quite possible true. But the 500 is not cheap, is it worth the risk? The makita type were made as building site chargers so designed for iffy supply.
