I'm looking for a more efficient way of turning our slabwood from the sawmill into logs for our boiler and for selling for wood burning stoves. I'm wondering how good the Bilke S3 might be for the job. I see that it take up to 340mm wide pieces which would suit our needs. I'd be glad to hear of any experiences. Cheers. Tom.
34 minutes ago, Mr Woody said:
Look at the Posch Kindling machine.
Thanks for your reply.  I'm looking for a machine that will cross-cut. Kindling machines need the logs cut to very accurate lengths. I'm looking to produce logs not kindling. Cheers anyway.  Tom.
27 minutes ago, Woodworks said:
340 is very wide. If they were narrower one of these would be good
I did have one of these, the biggest one from the range, but the slabwood that I need to process is too big for that machine.  Cheers. Tom.
Edited by Tom at Heartwood
Does it defiantly take 340mm? I had one and am pretty sure the largest log diameter it would take 8inch, which is a little over 200mm.
If it will take the size of material you require, then yes I think it will work extremely well. IME they are best run on a large high HP tractor. That way you can keep the revs low, which means it operates at a more manageable speed and you will get larger more uniform logs. On a small low HP tractor you need the revs fairly high, the machine runs very fast and you tend to get much smaller logs and a lot of smashed up bits.
Thanks, that's useful know. I got the figure of 340mm from the manufacturer's specifications. Can I ask why you no longer have yours? Cheers. Tom.
Read more
Just wasn’t using it enough, manly because I started drying smaller material in lengths and then cutting to length with a saw before putting it into my boiler. I have a poshe 350 processor and a very large 60tonne splitter, I just found I didn’t have time to use them all.
