Just now, Paddy1000111 said:
How old is the hedge cutter? What can happen is rubber parts that are swollen/degraded can fail when you switch from petrol to aspen as the aspen sucks the petrol out of them
done 2 hours work
As a user of Aspen, both 2 and 4, for several years in multiple machines, new and old, I doubt very much the fuel has caused the problem; especially so with a new machine.
I think you need to look into the hardware so to speak.
I sincerely hope I'm right.
I am going to put regular 2 stroke back in them tomorrow, see if it makes a difference
There is absolutely no reason for any machine not to run on Aspen. But, to be honest there is a very slight difference in density and volatility between petrol and alkylate fuels ( Huskie fuel is also an alkylate).
Because of this slight difference some machines will need slight retuning to make them run nicely on Aspen (or Huskie fuel).
This adjustment is very simple and can easily be done by anyone in the know.
It does concern me however that these hedgecutters are running so badly on Aspen and I doubt they are running quite properly on petrol either. Many machines need slight adjustment to the carbs on dealer PDI even to run properly on petrol.
I would pop this machine back to your dealer for a tune.
