What are peoples thoughts on the Deutz dx 120 for use in the woods and some hauling, someone I know is selling one at a very reasonable price and I'm tight, dores anyone use one at all or similar
  On 12/01/2021 at 22:15, s o c said:
I think gearbox was  weak point of DX
Expand
Think the clutch was the weak point if not respected. Couple of farms near me had them as plough tractors in the 80, remember see one drag a 8 wheeler out of a field that thing would pull.
Hydraulics had high flow rate compared to other tractors of its time.
Might have dry disc brakes exposed under the cab, can be a fire hazard. It’s the linkage at the bottom of the gearstick that wears out, should be an easy fix though. All the controls are rods and links so a can of wd 40 would be handy. Bomb proof air cooled engine if there’s no oil leaks to clog up the cooling fins.  4wd or 2wd?
Expand
Its a 1984 4wd model
Read more
