37 minutes ago, woody paul said:
Got a question has your chipper be running at full capacity for long periods of time, like feed control cutting in all the time.
No, you switch it off when you go home fr tea. K
A425 is 245x200mm infeed
A540 is 210x190mm
whats the Först?
I’d have to look up the opening size to be honest.
Generally just go by the max dimension it will chip. Or the 200mm
Although the bigger opening would most likely speed up chipping smaller brash getting more through
But essentially there is a huge size and weight difference between those two Jensen models with very little difference in large timber capacity. 190 v 200mm.
At a glance there doesn’t seem much point getting the a425 over the a540.
Just wondered if there was something particularly trick about the 425. ??
I dunno to be honest .
A425 has 15 extra horses, bigger heavier flywheel, bigger feed opening and slightly bigger hopper opening.
Its generally a higher capacity chipper than the a540.
All 8" chippers will chip a log up to 8"dia... But some are happier than others to do it all day, or drag in whole 8" diameter trees/branches without snedding
That’s my thinking. It doesn’t chip bigger really but will have higher productivity / output per hour
Probably a big difference in price .....
The 425 just seemed a bit lost in the line up. I’d miss it and hop up to the 10 inch chipper. A decent chipper all the same I suspect though.
Its the ability to make brash go to nothing that does it for me >   Then I would keep anything that looks like fire wood  .
1 minute ago, tree_beard said:
Agreed, Jensen always seemed to have a vast array of quite closely specced machines in their range. Those crazy Germans...
 Crazy Germans ! There is a thing ! 😁
