Aspen 40:1 mix
IanW
I don't know what oil is in Aspen but you shouldn't harm anything as long as it's fully synthetic oil. In future I would buy the 4 stroke aspen and self mix. I like Stihl Ultra oil @ 40-45:1 so I mix it myself usually although I have been using normal petrol recently and saving the aspen for storage as I am getting put off paying almost £5 a litre at the moment.
Been mixing Aspen 4 with Red Line at 50:1 for years ( well since Aspen came out ) Don't see why you could not mix at whatever ratio you want but can't see the need to go below 50:1 .
It's more for peace of mind. I use the 1L bottles with the measuring unit on the top. I don't 100% trust the measuring cups or their ability to fully empty so I go up to the 100ml line (50:1) and then a touch over to around 110ml to 115ml or around 43-45:1. It probably makes no difference to the engine but it gives me peace of mind that I haven't under oiled. It also means that if I accidently stick over 5L in there at the pump then I don't run lean. I serviced my 3 year old 261 the other week. Plug was a nice biscuit colour and I boroscoped the bore, the piston was still shiny on top and there was no damage or signs of wear at all to the cylinder or piston skirt. The head itself was also nice and clean. Personally I would rather "over oil" slightly and have a dirty plug or a dirty piston than under oil and when I push the limits of the saw cause some damage.
Edited by Paddy1000111
Red line says , on the bottle , can be used at 100 : 1 ratio so I am happy at 50 : 1 . Never had a problem and my mind is peaceful ?
Horses for courses I suppose ? I just remember there being stories of the US loggers with 660's and they were running 50:1 as per the manual. Some guys were reporting issues with loss of compression/damaged cylinders and the ones running 40:1 weren't having an issue at all. How true they are we will never know. As far as I'm concerned I'll run as much oil as I can without it starting to have negative effects. If anything the newer, cleaner burning/less dirty oils have opened the gates to running heavier oil ratios without the negative impacts. There's a reason that car/truck/machinery/shipping engines have built in oil, they last longer.
Most of the " small engine " problems in the U.S. is down to the high content of ethanol in pump fuel .
Edited by Stubby
