Rosanbo
DIY felling - Winch to pull over tree
I'm not a professional
I have a MS170 with a standard pico 3/8(?) chain and a 14" bar
This is a sycamore tree about 30 ft tall.  For convenience I think I will be cutting it about 4 feet above ground  It is 23 - 26 cm diameter.
The trunk splits into 2 about 15 feet up.
I have a climbing rope 40m long / 132 ft measures about 13mm diameter.  I am not a climber so I don't know how strong this rope theoretically is.
I am going to tie the rope or a strap to the the tree trunk just below where the trunk splits. This will be about 10 ft higher than my cutting point.   Should I go higher, which would mean tying to one of the smaller trunks?  (I think I should tie to the main trunk).
Should I tie the rope around the tree trunk or should I use some sort of purpose made strap?  If a strap, can you link to one I should buy please?  And in either case any pictures of the tying method would be appreciated.
Should I use my climbing rope or should I buy a better rope or a strap 40 - 50 ft long?  If not my climbing rope, can you link to what you would recommend?
I am going to use a winch to pull it tight then I am going to cut it down.  I have been watching a lot of "Bucking Billy Ray Smith" he is really good I hope you will agree.
I'll buy some wedges just like Billy Ray uses.... ?
Have you got a winch you would recommend? because I am thinking of buying this one I can get it much cheaper than this price.
https://www.silverlinetools.com/en-GB/Product/ProductDetail?ModelName=360375
I don't think I will have any problems doing it just looking for some advice.
Edited by Rosanbo
Share this post
Link to post
I'll buy some wedges just like Billy Ray uses.... yes?
get someone in who knows what they  r doing my friend.
  • Like 6
Share this post
Link to post
Brave man .
Share this post
Link to post
4 minutes ago, gary112 said:
Is this for real or just a p take
Either way we need it filmed if at all possible . 👍
  • Haha 3
Share this post
Link to post
I will try to film it.  I'm going to do it no matter what so any help on my questions would be in my best interests.  I know it's a small saw, but I'm sure it can do it.  I have cut a couple of  similar sized trees with it before.
Is that Buckin Billy pun ? Nice one if it is.
Share this post
Link to post
Neither am I but I'm not sure I'd ask professionals to give me a free complete guide to felling a tree!
I am curious though, why do you need a winch? Is it likely to damage something if it falls the wrong way? Do you have a photo of the tree?
As someone who does like to do things themself, it does sound like a job you need to get someone in on.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
