Sign in to follow this
Justme
Adding hydraulic ports
Has anyone added hydraulic ports to a WP30 or 36?
I have to be able to split big rings using the processor as the power source.
Preferably switched ports / valves so they can be turned off when not needed.
Ideally plumbing in so the machine can work at same time but prob not actually both working at same exact time.
The pump has one in & out port so for full power I think there would be best for the feed & straight back to the tank return.
Share this post
Link to post
Would not have thought you can pumb it up and run both, but a simple diverter valve after pump to send flow to splitter or as it should.
Share this post
Link to post
Sorry no not run both at same time but be able to leave set up & use which ever one is needed without having to keep plugging in or changing valves.
So with good timing a second person could make a split whilst the processor operator is dealing with other things.
Slightly concerned the pressure bypass on the splitter could reduce flow & pressure to the processor so would then have to use a valve.
Share this post
Link to post
Can you not just plug in to tractor hydraulics.
What tractor?
My processor is self powered.
Share this post
Link to post
2 hours ago, Justme said:
Not valving would allow the conveyor to still take logs away.
Does the conveyor run constantly or slow at all when the saw or splitter are in use?
What you want to do is catered for by having a spool valve with a high pressure carry over  to a downstream spool but it's hard to see how to make that work without a new set of spool valves.
Share this post
Link to post
The conveyor does not seem to slow at all in use.
Dont want to mess with existing valves as they need to be set up delicately.
I wonder if it already has a flow through set up.
Will need to follow the pipes to see how they split.
Share this post
Link to post
I think @Woodworks has a similar machine, perhaps he knows the circuit. In the absence of the circuit diagram all I can think is to have a solenoid controlled diverter that was only enabled when the processor operator allowed. This would stop the conveyor.
Share this post
Link to post
I dont think I will need the full flow & the conveyor only uses a limited flow.
I have the diagrams but to be honest its easier to just look at the pipes.
I am slightly worried that any valve could stop all flow whilst changing over & cause pump damage if done with engine running.
Preference will be to have the valve if needed just turning on & off the flow to the QR port.
I could just un plug the feed which would be ok for jobs that are all for the splitter but not user friendly for mixed jobs.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
