Hi All
I am considering buying a PTO stump grinder and have been looking at a Miller 150 which is
missing what I believe is a slip clutch joining the two pto shafts.
Is this a decent machine for 115 hp tractor and can you still get parts ?
Any advice appreciated.
Thanks
Interesting machine.
I am sure you could always fit a suitable slip clutch for an agri machine to the drive-line.
Any more pics?
1 hour ago, Peasgood said:
More likely a wide angled joint to allow for the sideways swing rather than a slip clutch.
I am not familiar with the machine though.
Yes I would expect a slip clutch to be at either end rather than the middle
Thanks for the replies so far.1378048316_miller150complete.thumb.jpg.ecc9c95596a72d8dc58a0b7cf5efea9f.jpg
I've found a picture of an original machine and I think it appears to be a bearing mounted in middle.
If I could locate was an off the shelf bearing that fitted it would be a bit help.
