I’m moving over to running a palax 100s via an electric motor. I’ll start with just using the pto but come winter I’ll move in doors and power via a generator.
The instructions say it’s a 15 KV motor but the dealer recommended that I’d need 40 KV as to get the processor up to speed takes a lot of power. Has anyone got any experience on this?
Edited by oldoaktree
He is spot on in what he is saying. Its 3 x the startup power required to run a 15 KVA  3 phase motor which you would most likely need running a processor that big. Have you a 3 phase supply ??
Edited by topchippyles
6 minutes ago, eggsarascal said:
It's Watts x amps = voltage, I think. Someone better at maths than me should be able to give you a clue.
His dealer and myself has told him he needs a 40 kva supply to run a 15 kva motor, No question about it.
4 minutes ago, topchippyles said:
His dealer and myself has told him he needs a 40 kva to run a 15 kva motor, No question about it.
Who says you and his dealer are right?, Let's have it from an Electrician, Some about here.
Edited by eggsarascal
Because i have setup the same thing twice and my mate who did it all is an industrial sparky. I have a 3 phase supply in both my workshops and my one 24" 3 phase planer has a 15 KVA motor delta/star  but eggs knows best.
A 3 phase motor starts in star then switches over to Delta, you are pissing up the wrong tree, Les.
