7 minutes ago, carpenter1 said:
Do you store them out of sun light?
As I was just going to put a lorry sheet on top
I store them out of direct sunlight ie. in a shady part of the wood when not in use.
They spend most of their life out in the sun full of logs.
On 17/05/2020 at 08:20, coppicer said:
(1) Cages from an IBC tank. These are sturdy and a good size; this would still be my preferred option if it were not for cost and availability. £40 a tank seems to be the going rate, so a couple of dozen tanks would cost me the best part of a grand.
Shop around. I have 48 coming today after he drops 42 off to the other person sharing the full load.
Inc delivery around £16 each for just cages.
On 19/05/2020 at 12:17, Justme said:
Shop around... Inc delivery around £16 each for just cages.
That's a great price. Maybe I'm not looking in the right places...
On 18/05/2020 at 19:52, youngsbury said:
Has anyone thought of using heras fencing to make cages ? you can buy them off of eBay damaged for a few quid ! I used to use vented bags but now use used stock fencing wrapped round pallets as I’ve got loads of it 500+ meters used
Yes, thought about it but four panels would make a heck of a cage and then there's the issue of handling when you want some logs out of it:  just opening up one side could cause an avalanche!  I decided against but did seriously consider trying one for seasoning softwood.
? I meant cutting / bending  up the panels to make smaller cages to put on a pallets !
For chunks of softwood I was happy to seriously consider it.  I reckon they would have dried OK with a roof.
Academic now - I' not going to try; I'll stick to IBCs.
7 minutes ago, AHPP said:
Would there be enough airflow
This is what I wonder. There must be an optimal ratio of (external) surface area to volume for a pile of wood like this.
