1 hour ago, Rough Hewn said:
Got the 48" stihl, 56" GB and 84"GB.
All have different uses.
I started milling on the 880 with the duromatic bar.
Absolutely fine.
Never even needed an aux oiler.
Then I got GB bars....
Yes there is a big difference.
Now I only use the duromatic for cross cutting huge trees and stumps.
STOP BRAGGING ROUGHY- I HAVE AN 8 INCHER ON THE SLACK BUT DO GO BOASTING ABOUT IT ? 84 INCHES (BULLSHITER) KING KONG COULD NOT USE THAT ?
7 minutes ago, MattyF said:
I’m not convinced on Sugiharas , nose sprockets seem a little brittle , I’ve replaced all of mine at least once.
Is that on the big bars? I've had an old ms200 on one and that parted itself on the sprocket, I've another bar here 12" but no saw for it but can't recall how much switched seen.
STOP BRAGGING ROUGHY- I HAVE AN 8 INCHER ON THE SLACK BUT DO GO BOASTING ABOUT IT [emoji123] 84 INCHES (BULLSHITER) KING KONG COULD NOT USE THAT [emoji23]
Photos don't lie mate???
7 minutes ago, Rough Hewn said:
I have noticed on all bars over 48", they are pretty useless for cross cutting.
The flex is so much at 7' the chain just jumps off.
I was correct about one aspect,you aint no KING KONG-MORE LIKE A KING DONG ?
Surprised that 880 has the balls to drag that, or have you dropped sprocket size and full skip or hyper skip chain?
Edited by Big Beech
Might not be the 880 ???  haha if i said any more would have to shoot ya ?
Runs sweet on Oregon hyperskip.
I do use full comp on the 56" though.
[emoji106]
Friend runs a 44" and 60" and they are some heavy duty bars and the weight to prove it.
Love working on his woods ported 3120 with unlimited coil and H side carb.
